I am working on putting new Cal-Van inserts into my heads on my 98 Expedition 5.4 with the heads still on the block.
I have noticed as I am putting in the inserts, that the spark plug seems to be seating at different heights between cylinders when reaching torque. I have done 4 on 1 head so far.
I measure from the top of the head to the top of the plug and the distances vary from one cylinder to the next by about 1/8".
The Cal-Van has a cap at the top of the insert that seats against the original spark plug seat that is machined in the head. Is it possible that the original seats vary between cylinders in their machined heights?
More importantly, how critical is the distance from the spark plug to the piston? I am trying to determine if there is an insert problem causing the difference in spark plug heights, but more importantly, if 1/8" difference in heights between spark plugs would even matter.
Unfortunately, I have no way of seeing the spark plug position from the bottom of the head.
If anything, the plug would be further away from the piston from the original, not closer.
I will try to get some more accurate measurements.
