- Joined
- May 28, 2024
- Messages
- 5
Subaru – Robin SP170 engine installed in a 27 ton log splitter. It was not winterized last year and the carb was beyond recovery. Lots of rust and corrosion to the point the jets could not be removed. We threw it in the garbage and ordered a new one. After installing the new carb and it ran great for a couple tanks and then died. It still starts and idles fine but much over ½ throttle and it will die. After trying various things, I decided maybe the new carb could have failed so I ordered another new one (#2). Sadly, it had the exact same problem. In my quest to fix it thus far, I have:
Replaced the spark plug (has good spark)
Replaced the carb/intake gaskets
Sanded the spacer so it was flat on both sides
Checked coil spacing (within spec)
Oil is full (no oil safety switch on engine)
On/Off switch is bypassed
Cleaned gas tank (spotless now)
Replaced fuel line
Fresh Gas
Valve lash set to spec
What is frustrating is that it will run at full throttle if the choke is on. This leads me to believe there is air getting in somewhere.. but where? I have sprayed starting fluid and carb cleaner everywhere and nothing changes the engines behavior unless I spray it down the throat of the carb. The only things I have not messed with is to replace the coil or play with the governor. I have disconnected the governor and adjusted the throttle manually and it exhibits the same issue as if it was properly connected. I am at a loss and am usually pretty good at troubleshooting – especially SIMPLE small engines but this one is kicking my butt!! Any suggestions would be much appreciated ☹
Replaced fuel line
Fresh Gas
