I was wondering what is the general consensus on proving that one filter is superior to another. I would assume that the only way to 'know for sure' would be to do particle counts on the same vehicle, same driving conditions, same OCI with the same oil. While we can say that 'better' construction and materials would give better results, this is really nothing more than an assumption. To my knowledge, the only time this has been done is the M1 vs. Ea filter test. Even then, the results are only valid for the OCI used in the testing procedure. Has anyone, at any time done another similar test involving other filters?
There's alot of talking about how bad ST and FRAM filters suck, but as nearly as I can tell this is based on the feel of the filter media and construction of the filter whether it be cardboard endcaps or the E-Core structure and not because of documented results. (Note that I'm not saying this is wrong - only unverified) Also, there are claims that WIX is better than PureONE or vice-versa.
Don't get me wrong, I'm not trying to start a nuclear war over oil filters. My reason for this post is my recent purchase of a pickup. While I look for a filter brand, I'd like to be able to sort my data into three groups: data from testing, logical assumptions, and opinion.
From what I can tell here are examples of each:
Data from Testing:
M1 filters appear to be more efficient than Ea on short OCI based on particle count.
Silicone ADBV have a longer lifespan than nitrile rubber.
Logical Assumption:
Orange can Fram elements frequently are not glued to the cardboard endcap properly, so they may be inferior because of unfiltered oil bypassing the element.
The 90915-20004 filter for some toyota engines is superior to other filters in the same application due to it's unique construction.
Opinion:
E-Core is a bad design that is prone to failure, even though this has not been observed.
K&N and M1 are actually the same filter, just with a different enclosure and a nut welded on the K&N version.
What are your thoughts? Maybe I have something wrong? Again, I'm not saying that assumptions and opinions are wrong, I'm just trying to sort out my thoughts.
Data from Testing:
Logical Assumption:
Opinion:
