My 3.3l dodge V6 has about 80k miles.
Of late, its been burning a quart of oil every 1800-2000 miles and when the engine is good and hot, I can hear a tapping at low rpm. I have been told that "tap tap tap" is lifters, but I am no engine guru. It sure weren't there orginally.
The oil gets changed regularly -- I tend to run what is cheap. But I had the bright idea that I would run some Mobil 1 extended performance oil -- the stuff touted to run 15k miles -- and just change the filter ever 3k and keep it topped.
So with the M1, the oil use was about the same, maybe a little more. And the tapping was unchanged at first, but seemed to be getting worse, after about 7k of M1.
Then, after a 5 day vacation, I restarted the engine and the tapping was horrible, persisted even at higher rpm for perhaps 30 seconds. The oil was a little low, so I topped it. But then I started to mistrust my M1 experiment.
I went and switched back to Dino. Tapping went back to before, only present when the engine is hot. Clearly less than with M1 extended. Was using 10w30 both times.
What do you think?
Was the M1 so "slick" that it was not lubing the lifters? Did it drain back out of the filter?
Maybe I'm just crazy.....
Your thoughts please!!
OH, bonus question -- what do you think about 15w40 Delvac 1300 HD diesel oil in a rattleing V6? Think it would extend my engine life?
What do you think?
