- Joined
- Jul 2, 2007
- Messages
- 5,293
Does anyone know if there is a Flow Rate difference between the Delco and Wix vs. the other designs. 2nd picture down in the photos at top of this thread: if you look you will notice the Delco and Wix have a smaller diameter opening in the middle vs. the Supertech and FRAM (opening where anti dain back valve is mounted).
I recently compared a Purolator Premium Plus unit (15436) to the Delco PF457G and noticed the Purolator had the same larger diameter opening as the Supertech and Fram units.
I wonder if this would effect Flow Rate, or if it causes the OEM design (Wix, Delco) to function differently in some fashion vs. the others?
