Originally Posted By: turtlevette
Most of these discussions go:
Rednecks - eliminate the epa, let's go back to dumping poisons on the ground
Moonbats - everyone should drive a Prius
Realist - forget hybrids that cost $2500 to replace the battery (or Tesla EVs that cost $30,000 to replace the battery). Small standard cars are the way to go... like the Europeans do. They've had 40-to-60 U.S. mpg-equivalent cars for decades, because most of their cars are 3 or 4 cylinders. They even have one that is just 2 cylinders!
Also slower speed limits that reduce air drag & increase MPG. I would keep the speed at 70 in the "great empty" part of the country, but reduced to 45 in zones that the EPA designates "non-attainment zones"... like California's coastline. Slower speeds == less energy burned == less smog.
Diesel. It not only gets higher MPG... it also burns fewer BTU/mile, so it's far more efficient. And with modern urea-based systems (DEF) the diesels are as clean as the gasoline cars. Greenercars.org rates the Chevy Cruze TD equal to a gasoline Civic.
