Solar battery maintainer: worth buying? capacity needed?
Elkins45
Site Donor 2026
Northern KY
I’m thinking of getting a solar battery maintainer for the trolling motor battery on my boat, since it’s normally parked out in the yard where it would be annoying to string an extension cord. How much trickle charge capacity does the average lead acid battery need? Are there any particular units you would recommend? Harbor Freight sells a couple. The cheapest one is only 1.5 watts so that’s like 0.1 amps and probably barely enough to maintain a lawn mower. I’ve seen a couple of 30 watt units, that’s 2.5amps and would likely do the trick, right?
First off, what capacity is your battery? With 50 - 100 Ah I'd get at least 10W or 1A. With 0.1A it could 'charge' the natural drain, but hardly to charge a weak battery. The latter task is better suited to conventional chargers instead of solar maintainers.
Btw, 'capacity' is what your battery has, explained in Ah (Ampére hours).
I think some of the solar panels are not regulated so they tend to overcharge. I've also heard that they don't put out nearly the amount of amps that they state. 2.5 amps will charge up a deep cycle battery. It would take some time thats for sure!
I have been using a 1.5W unregulated panel and it's worked great for years. I'd buy another, but the same HF one now is unreliable.
At 1.5W, the output is so low that you don't need a regulator.
I use a 15watt solar panel with controller from Deltran, charges winch battery on car trailer. Not used often. If you use boat often it may not fully charge.
Save yourself some money, disconnect the battery, bring it into the garage and hook the regular battery charger up to it every 3 months.
I only need it to maintain it while off the water. When I’m using it I can plug in the onboard charger every night.
I would go with a 10 watt charger, it should do the job of maintaining. No controller needed. I use a 7 watt panel and its just enough to keep the battery from losing it's charge. Mine is amorphous technology which is apparently better from what I've read because it charges better in lower light conditions than crystalline. It's made by Coleman.
