Originally Posted By: Petrou
Which oils meet spec for GM. Mine is a 2002 but im still not sure how to find the spec and who meets it. thanks
GM6094M would be the mfg's spec as has been stated. Also, the API spec/service level requirement at that time would be SL. Just look on the bottle. Most any oil will meet the GM6094M spec. It is not super hard to meet.
The current GM6094M spec would call for API SM oil but in 02 it would have been SL. Warranty should be long gone on it by now anwyay so it really doesn;t matter. GM6094M is nothing special so just pick a quality oil and you are good.
The actual cold weather performance of that spec, which is the meat and potatoes of the spec, would still be the same. Just been updated to add the new API service level. So any current GM6094M oil will be ok. Just won't have as much ZDDP as the oils around when the vehicle was new. Should be no problem using the current SM oils though.
