The motor guy
- Joined
- Nov 29, 2009
- Messages
- 10,258
Odyssey promotes their agm batteries big time for atvs and side by sides. I guess they dont care about the regulator on the machine?If your machine came with conventional then you cannot use AGM because the resistance in AGM is lower and will draw more current from your charging system which could overheat a regulator. And the higher current could potentially overheat the battery. Maybe that's why you've had bad luck with them.
As for trickle chargers, if you feel you must use one then put the charger on a timer to run once a day so it's not constantly dumping current in. Electrolysis causes water to split and vent out as H and O gas. I've read on wikipedia that the H gas can go right through the plastic case on AGMs, though most of it recombines back to water in sealed batteries.
