I’ve had this Husqvarna 30” snowblower with a 10.5 Sno King for 10 years. It’s always worked fine but there was a pretty good gap between impeller and the housing. Finally got a cheap impeller kit off Amazon and installed
yesterday before the snowfall. It was a bit of a PITB to find a good spot to drill because the impeller is bent upwards at the ends and there’s a lot of support and bends on the underside of each paddle.
For those that don’t know, this is basically a rubber mudflap that seals the gap in the impeller housing. The snow today was very dry but it throws a good 30-40 feet now, significantly farther than before . Really wet stuff used to just barf out of the chute so I’ll report back with the next wet snowfall to see what kind of improvement I get there. Overall, a great mod, wish I’d done it sooner.
