Snow King 9hp snowblower oil change
MN
Snow King 9hp. -- Maxlife Nextgen 5w30 out, Mobil 1 0w40 in. The MLNG was a bear to start at -30f last week and I'm hoping the 0w40 will be better. Am I right?
A little.
I just use Amsoil Sig. Series 0w30 in my 10HP Toro Snow Launcher.
-30 is extreme and I assume not "normal" , not much going to combat that extreme, other than preheating it somehow.
Unfortunately we have had more than a few days that cold this winter. I did end up heating it in the garage for a while then it fired up.
I put a space heater blowing at the engine and remove the spark plug and warm that up for a difficult cold start. BBQ lighter on the sparkplug tip for a minute, install quickly and fire it up.
possum328, easy starting at -30F is a tall order.
You'll probably get good, if not great, service from the Mobil 1 0W-40. However, between now and next oil change, I'd research 0w30 oils to see which has the lowest pour point.
Valvoline MaxLife Next-Gen is a bit of a synthetic blend (some Group V, I believe) with decent cold flow properties. To significantly improve on its performance in punishing cold, you'll want to carefully choose a successor by looking at specs on product data sheets.
I have seen people use dip stick oil heaters on snowblowers the plug in kind. Seems to be a good idea I guess? Just plug it in a day before the storm to heat your oil.
The best oil for easiest pulling over I have used is Arctic Blue 0W30 used in my 8.5HP Snow King for years and now in my 13HP Briggs & Stratton snowblower Arctic Blue can be found at Fleet Farm.
I am using Rotella T6 5w-40 synthetic in my 17yr old snowblower, 8hp Tech. It is kept in an unheated shed. It takes a few pulls at -20, as any oil would especially if you are using the pull rope. It is just plain COLD here and things do not want to operate like they should, unless in a heated building. I have an attached uninsulated garage that stays around 10-15 above even when it is -25. A heat gun works well to warm things up quickly also.
Cowboy up man, and pull that rip cord with all you got!
I've got MLNG 10w30 in my 5hp Tecumseh, and have no problem pull starting it in our current -15° weather. I've always got the electric start as a backup plan if I dislocate my shoulder or something.
I use Mobil 1 Advanced Fuel Economy 0w30 in my 5 HP Tecumseh. I use the electric start for the first start, I'm lazy. The Mobil 1 Advanced Fuel Economy 0w30 works very well IMO. I like your back up plan.
