Smoothest idle?
1970`s Toro mower with 3.5 horse Tecumseh motor. and Kohler K engines..
Originally Posted By: HemiHawk
Honestly? My Jeep's 4.0 is buttery smooth (at idle). I don't know how much of that has to do with engine design and maintenance, vs it being a straight 6 setup. Maybe straight 6 BMWs are very smooth also.
All straight-sixes are very well balanced, but IME the Jeep 4.0 has some mild random shuddering at idle more related to uneven combustion events compared to some other inline sixes. Kinda like a big-cammed v8 can be perfectly balanced, but still really rough at idle just due to the cam profile causing poor cylinder scavenging at low speed. I don't know what it is about the Jeep that makes it do that, but I have noticed it. Just a hair off idle, though, and the two I've owned were extremely smooth.
The 3.6 in both my 08 Malibu LTZ and my wifes 2015 GMC Terrain DENALI are very smooth at idle.
My 2006 Sentra with 166K miles and 70K on Bosch double platinum plugs is very smooth at idle.
Smoothest in order:
1) Mercedes M272 3.0 V6 - Can't even tell its idling and sounds like a turbine when I wind the tach out.
2) VW 2.5 - 5 banger. Had the weird 5 cylinder growl on romp but smooth as butter at idle.
3) Mazda 2.5 MZR and Skyactiv 2.5
4) VW 1.9 TDI
5) VW 2.slow
6) Dodge Neon 2.0
Definitely less refined the fewer cylinders. Had an ex or two with the Toyota 1AZ-FE (2.4) and to this day i still don't know why it was praised so highly, guessing it was just because the Toyota badge. That thing was no better than any 2.4-2.5 that came out around the same time.
I had a 1956 Cadillac Fleetwood once the engine was warmed up you couldn't tell it was running. It was the most impressive vehicle I have ever owned.
Some inline 6 engines have less than ideal fuel/air mixture distribution, and that may be a cause.
This may be why Nissan used 6 throttle bodies in the RB26DETT.
My LS400. Doesn't even move on start up. My DOHC 03 Cobra was smooth too. I think the lower compression and boost friendly cams helped.
