I know the flexible aluminum drier vent ducting is easy to work with, but if you can use PVC or some other smooth walled ducting you'll have faster airflow due to the smooth inside surface. As an example, I've read that highly corrugated drain pipe has 9 times the flow resistance of smooth walled drain pipe (I'm assuming this is for water since it is drain pipe. Even with air though, a 3" corrugated duct can flow as slowly as a 2" smooth duct.) The pipe in effect flows air, or water, as if it was narrower than it actually is due to the increased resistance due to turbulence. The PVC can also easily be flared at the open end which has a big effect on the ease at which air can enter the tube (see my post on airflow in ducts with different shaped openings.) Here are some articles about making cold air intakes which mention these things:
http://www.autospeed.com/A_0009/article.html
http://zhome.com/Care/airhorns.htm
