smaller snow tire size?
Also worry about the overall size in diameter and width, load range, and the wheel offset.
Tire rack is a legit vendor; they would not recommend it if it wouldn't work.
Elantras in 3rd world countries probably roll on 195/65/15s.
If the load rating is right, you should be fine.
Narrower is of course better in poor weather because it bites through the water, snow, and slush better.
I agree all the above and can't think of anything more to add. SO just chiming in to say go for it!
I've ever seen ads from retailers here with wheel and tire sets that have lower load ratings than the OEM tires. Unless you carry aggregates in the trunk with sumo wrestlers, it's hard to overload tires on a sedan. I ran tiny 13" tires on the Neon for years without issues as they were never close to being overloaded. Just great deep snow and slush performance. Those 15" ones from the tirerack sound great, I would run them without a second thought.
Originally Posted By: Donald
GF has 2013 leased Elantra with 215/45R17 tires. She wants snows and TireRack suggests 195/65R15 tires and steelies, to save money and better in snow.
Comments?
Pretty sure the base-level Elantra comes with 195/65R15 tires, so it should be fine. Unless Hyundai tacked on much bigger brakes or lowered the car a bunch or whatever---but I doubt it.
There have been at least two threads here from folks looking to replace the OE 17" rubber on the "sporty" Elantra. Seems strange that Hyundai went that big and low-profile even for the sportier trim. Less than an hour ago I was out in my Saturn in Electra. The upside to narrow, high-profile, well-siped T-rated tires became clear more than once....
I still would not go lower on the load rating. Even if you don't have people/things in the car, a lower load rating tire will not deal with the extra heat you're generating. That will lead to reduced life and a possible blow-out. Not worth it to save a few bucks. In some states, you'll fail the inspection.
Originally Posted By: andyd
I would look for even higher profile 195 75 15s.
I wouldn't. 195/65/15 gives an overall diameter only 1.5% off, meaning that the speedo readings will only be slightly wrong, under 1 mph difference. 195/75/15 is more than 7% off, meaning speedo will be slow by nearly 5 mph.
Overall diameter is important for more than speedo settings too. Odometer and torque control are affected.
http://tires.about.com/od/understanding_tires/a/Plus-And-Minus-Sizing.htm
http://tires.about.com/od/understanding_tires/a/Why-You-Should-Downsize-Your-Winter-Wheels.htm
http://www.miata.net/garage/tirecalc.html
Good luck finding tires in this size.
That size hasn't been made in a long time.
I run 195-65-15 in winter and 225-45-17 the rest of year on my corolla. What about 185-65-15? My guess is u can run either the 185 or 195 with no issue. As long as the 185 wont exceed 3%. Plenty of tire options in that size and also cheaper than 17's.
should be fine. Thats exactly what I ran on my 2009 Elantra touring that came with 215/45R17's
more sidewall is excellent in absorbing rim destroying pothole edges.
The Miata dot net tire size calculator is a useful tool.
By using it and slightly adjusting tire size, I was able to save $100 on my winter tire package. The tire sizing specification differences were negligible.
However it is a Java Runtime-based application. There are security risks associated with using Java in a browser, and you will probably have to download Java from Oracle. OS vendors (Apple, Microsoft, etc) do not recommend enabling Java in the browser or even downloading and installing it.
Now, I personally have no issue with installing Java on my machines, because Oracle is a trusted vendor and you can disable Java in your browser preferences. So, you could enable it to run the tire size calculator and then disable it, which is a safe way to use it.
There also could be applications on your computer that use Java. Again it's a matter of trust … if you trust the app it's OK, if you don't it's not.
The OS vendors recommend on the basis that you don't have a clue what you're doing. So they do not recommend Java. But it is safe if properly used and configured.
Just a heads-up.
Also note that people confuse Java and JavaScript. There is nothing in common with the two except an unfortunately similar name. Allowing JavaScript in the browser is OK; allowing Java is not unless you trust the page you're using it with.
