I've been reading info about sludge buildup in engines. Some articles state that sludge is caused in poorly designed engines by extreme internal engine temperatures that may occur in specific areas due to poor lubrication. Or just running an engine at a higher than normal temperature due to a bad thermostat, low engine coolant, etc. Or from heat generated by turbos that is not properly vented. Or from a lot of short trips where the engine does not reach its normal operating temperature before being turned off. This last reason seems to me to fly in the face of the previous ones. I can't envision how sludge could be caused by BOTH extreme heat and also by lack of heat.
The reason I was curious about this is because I ran my Civic for awhile with the "check engine light" on, and the temperature gauge pegged at the top of the scale. This was caused by a faulty O2 sensor. I called my mechanic before driving to his garage and he said just to ignore it. I know the engine got really hot during that trip. Also, I do do a lot of real short trips where the engine really never warms up.
Does anyone know the straight scoop, or can they point me to some definitive accurate data about the cause of sludge? If my engine has some I was thinking about giving it the AutoRX treatment to try to dissolve the stuff. BTW, what is the easiest way for me to determine if it is present? Thanks.
