SLIP 2000
Read the article labeled "filthy fourteen" and you will see real world results. I use it and haven't had one complaint. I switched my AR 15 from oil to EWG from slip 2000 and as soon as I rack the charging handle you feel how smooth it is!
Works great I’ve used it for 8+ years. I prefer the heavier weight one they have verses the regular. It seems to stay in place better when the gun is holstered and doesn’t run down to the muzzle.
I have used Slip 200 for many years in ARs with fine results. For semiautomatic pistols I prefer a grease on the slide not an oil.
Slip 2000 also works great as a sewing machine oil.
