Slate EV Pickup
I don't think weight distribution is enough. I've had FWD, RWD, and now AWD. I work weird hours and I get plowed in a lot in the winter. Anything 2WD regardless of which wheels are driven really take sending it to get over a deep snow pile. My Model Y Performance just pulls right through it. I really have to commit to get the RWD Model 3 through it. My wife stays put when the weather is bad. I don't have an option to sit it out and going to AWD was a game changer in that regard. The GTI was a disaster being 1000lbs lighter and was so quick to build boost into wicked wheelspin.
As far as only having two driven wheels, I still prefer RWD no matter the platform.
EV pickups usually only have room for batteries under the bed which results in a more neutral bias.
It seems they all run batteries between the wheels themselves. There's definitely benefit in AWD that RWD alone can't handle. I'm speaking in generalities of vehicles in general and not the typical light rear end of an ICE pickup.
I assume the battery will be under the bed and it will have something like 40-45% front and 55-60% rear weight distribution. So with snow tires it will climb up a pretty steep hill in the snow. My Focus is around 60%F 40%R and it climbs the hill on my snow covered driveway remarkably better in reverse.
Yes, a 2WD with its weight biased over the drive wheels will spin out less readily than one without. That doesn't change the fact that AWD/4WD will handle a steeper incline if all else is equal.
A step in the right direction IMO.
It seems however they might have went a bit to far with the minimalist theme just to prove a point at the cost of the users creature comfort.
The power windows I would be willing to live without, not a big deal.
No radio? Really? Even just the most basic am/fm with blue tooth and 2 speakers in the dash would make this so much more appealing. I would suspect the aftermarket will step in here if these actually make it to market and become popular.
Also I don’t see one cupholder? Again, I think this is more just to make a statement but maybe that’s going a bit too far?
Still would rather this than the usual screens everywhere and a bunch of “features” I won’t use and don’t want.
I have a feeling they might sell, and be a real disrupted to the EV industry, especially Tesla and BYD if it takes off. There are some people spending that kind of money for an electric golf cart. I'm sure Bezos will offer more expensive models with creature comforts, longer ranges, etc. driving the cost higher if they succeed with it.
What about cup holders?
I hope there is one, maybe that's the start of one at the very bottom of the 4th picture.
There are quite a few accessories on the website and in some of the videos I’ve seen about the launch. Power windows, cup holders, speakers, wheels, tires, lift kits, interior trim, lighting, bumpers, etc. will all available. I’d probably get the lift and AT tires and maybe the speakers and power windows but not much more. The 5 seat kit is kind of neat, depending on the price.
If it had at least an 8ft flatbed and 4wd, and a reasonable load rating, like 2-3k lbs and ~10k towing, that would handle most 1/2 ton truck duties.
I ran a 2wd 1 ton dump truck for years. I put a Detroit locker in it and got very good at throwing on tire chains.
When I saw 2wd, manual everything short cab,
I said about time.
RWD with posis is all I ever drove until recently when I got into FWD, and we historically got lots of snow.
More manufacturers should drop AWD and 4wd offerings
I fully agree about long box and payload, in a vehicle with the power train on the rear axle the vehicle weight difference and control systems to handle a 10,000lb tow is minimal.
An EV can be easily designed for continuous operation at WOT with control systems to derate before any damage could occur.
Hopefully the geriatric weight rating is legal bs but the actual chassis isn’t an aluminum can.
Sadly the equinox EV or a used FORD EV is likely a better deal at a similar price with better ratings but you never know how things will shake out.
Needs to be a king cab. You can't leave anything is the bed of a PU anymore.
That’s why I always owned RWD Suburbans with double bench seats as pickups.
The weather is so unpredictable and sucks to the point that even though a lot of things should be easier with a pickup you end up stuck with a cover or a topper anyway
NOTES + PREDICTIONS:
1. I read that the slender guts of power windows are cheaper to make than crank window hardware so I predict power windows will be available. I also assume plants which can turn out crank window hardware (CWH?) can be tooled up, even in Mechanically Sunset America.
Power windows are cheaper than mechanical because solely of volume, there are much cheaper mechanical available in the developing world due to cheap inferior materials available and labor. Weight and thinness drive down cost prior to tarriff affects due mainly to costs of low volume combined with shipping/logistical cost from the places that still make them cheaply.
Being in a whole new world, common rules of thumb might change.
2. It has AC.
AC does drive a lot of cost, at best it’s optional or you end up with an cheap inefficient electromechanical cooling solution
3. If they're smart, they'll include a power line to the seats for customization (addition of motorized seat/heated seat).
External Heated seat covers are $25, it’s minimal cost to include heated seats and steering
4. Ford will take 'em to court because it looks like an older Ranger and a Flex had a baby.
Unlikely considering production intent rarely looks like these cgi renders and Literally every so called SUV, minivan and crossover Looks like clones of one another so I doubt minor nods matter anymore
For 20K, this little guy would be a pretty compelling proposition.
A good commuter vehicle and with some utility value.
The range would be fine in typical local use for those who invest in the infrastructure to be able to charge efficiently at home.
RWD is hardly a deal breaker, since most of us who've been driving for a while have driven many RWD vehicles through all sorts of horrendous winter conditions.
Overall, an inexpensive new vehicle that could be used and abused for the next decade or so.
Has nothing to do with "knowing how to drive".
4 driven wheels is better than 2, there's no argument to that fact.
We have snow October to May and mud and ruts or moon dust May to October. There's a few weeks a year the roads are fairly decent.
Most trucks stay in 4wd most of the year. It's rare to see cars, usually just tourists in summer.
4wd many times gets folks significantly stuck further down a road they don’t belong on vehicle or skill wise.
agreed, I would love to see the number of available new AWD, 4WD offerings to drop massively.
Most do not need it and if you do pony up, would make vehicle shopping simpler and cheaper plus should drop parts cost when you need repair.
When I want to buy something finding a used 2wd/rwd is nearly impossible, would love to see that change
