Originally Posted by edyvw
Originally Posted by Virtus_Probi
Originally Posted by redbone3
I stand corrected. I never thought that the narrow channels in the thread were siping. Siping to me is cutting the thread with a heated blade by some guy at a tire store. Do the tire manufacturers claim their tires are siped? I don't recall any tire ad that mentioned siping.
I copied this from TireRack.com...
"Blizzak DM-V2 tires use Bridgestone's adaptive NanoPro Tech Multicell compound that features a water-loving hydrophilic coating and microscopic bite particles. The Multicell compound remains flexible in below-freezing conditions, wicks water off packed snow and ice while the bite particles deliver more grip and improve braking on glare ice. This compound is molded into a directional tread design featuring 15% more aggressive block edges (than the Blizzak DM-V1 it replaces) where wide lateral and circumferential grooves help channel water, slush and snow away from the contact area for added traction while 3D zigzag
sipes increase the number of snow biting edges."
This was actually the first snow tire I looked at.
Sipes also get filled with snow. Snow in sipes provide much better traction and braking when in contact with snow!
Not necessarily the sipes since there's not much area, but definitely the grooves. There are a lot of winter and all-season tire tread designs that are meant to have snow trapped in the grooves since snow sticks to snow. This one has a choppy set of grooves meant to keep snow from falling out.
However it's kind of odd. At least in California there's a requirement for "snow tread tires" about the depth of the tread blocks. In order to meet the requirement, an M+S tire needs to have at least 6/32" tread depth to qualify where those alone can substitute for chains. But with true winter tires the tread is going to be filled with snow that stays there, so exactly what's the purpose of requiring tread depth? A good winter tire isn't really using its tread depth to do much since the tread doesn't really bite through the snow.
