I just bought a used simplicity rider off my neighbor. It has a hydrostatic transaxle in it and simplicity's website states to change the hydrostatic fluid every 400 hour and every time the transaxle is serviced. The website stated to use a "4.3 pints (2.0L)SAE 30 Premium Grade Engine Oil." I was wondering if you guys would have any suggestions on the brand and type of oil to use. Also I was wondering if the 15w40 pennzoil that I have been using for the engine oil would be also ok to use instead of the SAE 30 that they say to use as hydro fluid. If I could it would make servicing easier. One oil for everything and not two different oils for two different duties. And if this practice would cause problems what would they be. I would like to hear all of your suggestions and comments.
Thank you
KC
Thank you
KC
