- Joined
- Jun 15, 2021
- Messages
- 191
I need to do a rear differential fluid change on my Ford 8.8.
I am using a Lube Locker gasket, and like it very much, simple, easy, no wait to set up like RTV, and no leaks.
A friend suggested that since I am using a gasket, and since I am only doing a fluid change, and since the differential cover does not have a drain, that I do the following (after making sure the fill plug comes out!):
1) Loosen all 10 bolts about half way, but do not remove.
2) Carefully break the seal at the bottom of the diff, and let the old fluid drain out.
3) Retighten all bolts in a star pattern, going to half torque spec first, and then again to full torque.
4) Fill it up through the fill hole and go!
Granted I would not get to inspect the inside, but my friend claims that for a quick and easy fluid change with a reusable gasket, the above is all you need.
Besides the chance of a leak, and the inability to inspect, does anyone see a problem with this... I know it is "quick and dirty", and will not get out 100% of the old fluid, but for a quick fluid change for a diff without the drain, or as a field expedient, would you do it?
Thanks
Thanks
