Yes, you can have non-solid SiO2, but only if you melt it. If I recall from my solid-state chemistry class, this happens somewhere around 1600 Celsius!
It is also possible that the SiO2 is colloidal (very small particles suspended in solution), but this isn't what that paragraph seems to describe.
I suspect that they're actually describing the deposition of solid SiO2, and you're absolutely right that it would cause serious problems.
Furthermore, ethyl silicate is probably susceptible to hydrolysis (i.e. it reacts with water), which wouldn't do much for its shelf life.
