you really shouldnt flush it this way, but the way i did it back in the day was to first drain the system of brake fluid. then disassembale the master cylinder, and calipers and clean them to bare matel inside (no more brake fluid) (i also did a caliper and m/c rebuild with kits i purchased at autozone at the same time)
while the calipers and master cylinder was off i flushed all the brake lines throughout the car with water. i then hooked up an air hose with a filter/dryer to blow out the water, and i let it blow for a real long time to make sure it all evaporated. finally i put the master cylinder and calipers back on and procedded to do the age old ritual of pump squirt pump squirt. it worked fine for me but these were older vehicles without abs and stuff.
dot3 and 4 brake fluid is water soluable (sic) so the water mixes with it and flushes it out.
the new dot5 felt a bit more spongy than good dot3-4.
the reason i dont use 5 anymore is the fact that if you flush your brakes every year or 2 you wont ever have a problem. its the OUTSIDE of the m/c and calipers the outer dirt/water seals that wear out, from heat and let contaminants in. so using dot5 is completely useless, it wont stop caliper sticking, only regular maintence of the outer durt/water seals will do that. if you have blown out outer seals, bleeding the brakes every 6 months wont stop caliper sticking.
the only viable use for dot5 is in a collector car that hardly ever sees the road.
also u notice i never said wheel cylinders, i dont own any cars or motorcycles that have drum brakes, id assume it would work but i dont have first hand expierence. heck i dont think i have ever even serviced drum brakes. my 71 porsche comes with 4 wheel discs from the factory
98 hondas dont even have rear discs
[ March 03, 2003, 10:26 AM: Message edited by: cryptokid ]
