I have propane heat for H/W and some baseboard heat, which makes one most aware of the cost of paying to fill the tank. My wife takes a shower about 7am and I do so about 9am. So, before I shower, I turn the valve back to Pilot. My shower goes fine, I even sometimes take a 2nd quick shower later on and/or do the dishes with leftover lukewarm water. Even better, on weekends we don't shower until 11am and can turn the heater back on right before use. Normally, I turn it back on the night before, about 1-2am.
So, that means 18-24 hours at a clip, no gas is burned to keep the water hot. Does everyone agree that a decent amount of fuel is saved? How much savings verses pita is different for everyone, by for example we heat with 90% wood over the winter which has to be schlepped in. I understand that the only thermaldynamic savings is the difference between storing +150f water and +75f water verses the differential of the ambient air. That is, plus 75 degrees over ambient. Reheating is a non-issue. Am I missing anything? PS In general, I set the water temp to use pure hot for showering, when the tank is empty, shower is over. That seem better than keeping super-hot water ready, just to blend it with cold.
