Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 4,913
This sump pump setup does not look right to me. I believe there should be a check valve on the left sump. The one on the right is a battery powered backup pump.
I have to lower both pumps, or at least the primary one for now, as the water level is up to the drain tiles. I don't know why these pumps were set so high. With the drain tiles partially filled, the basement has a musty smell to it. I hope the smell will go away after the drains are consistently dry.
What would you do to improve this setup?
p.s. I will be ripping out the ancient water softener and putting in a completely new system.
