I've got just over 63,000 miles on my 99 Chrysler 300M with the 42LE transmission and I'm contemplating a fluid change. Those of you who've read my past posts on the subject of ATF know I'm a stickler for using the specified fluid and ONLY the specified fluid. My 42LE came with ATF+4 in it, however I am considering using ATF+3 for the following reasons:
1999 was the model year that Chrysler switched from ATF+3 to ATF+4 and some 99 42LE transmissions were shipped with ATF+3 in them. There are no mechanical differences between the transmissions that shipped with ATF+3 and those that shipped with ATF+4.
From what I've been able to gather, the friction properties of ATF+3 and ATF+4 are the same, but the reason for introducting ATF+4 was to improve the lifespan of the friction properties, improve low temp performance, and to ensure that the factory fill could indeed function as a "lifetime" fluid. These were the only benefits of the Type 9602 spec over the Type 7176E. If that's the case, I don't see why I can't switch to ATF+3 since I'm planning to change the fluid annually from this point on.
Thoughts? Suggestions?
