OVERKILL
$100 Site Donor 2021
Originally Posted By: BuickGN
Knock sensors are reactive. The engine has to knock for it to pull timing and even then the timing gets put back in quickly then it knocks agian, timing gets pulled again and so on. No thanks, I will continue putting premium in my 11:1 TL and enjoy the extra power and gas mileage and without the engine damaging detonation. Not to mention higher egts with the timing pulled.
Now if the car doesn't knock in the first place then by all means run 87. I just don't agree with people saving $1.50 on a fillup of 87 on a car that requires 91 just to get a 2-5mpg reduction in economy that costs more money in the long run anyway. It blows my mind that people are so cheap that they will save a couple dollars on a fillup and cost themselves $10 in worse mpg.
Depends on the ECM I'm sure. Some will pull timing and then make an entry to the CL table that at X RPM under Y load and Z timing with ECT at R and ACT at S that knock occurred and will add a degree (or whatever increment it works in) less the next time those conditions occur and will continue to do this until no knock is detected.
This will eventually result in a CL table full of pulled timing and less performance. Even putting higher octane gasoline in at this point will make no immediate difference. The ECM will constantly "test" it's learned points and if it discovers it can add more timing, then it will do so.
Of course how this transpires will be dependant upon the brand of engine/ECM, how the base table is setup, how the CL learn function is setup....etc.
I imagine many of them in production are still of the "knock and respond" type that BuickGN has alluded to.
