Should I replace the timing belt?
Our pt cruiser has 73,000 on it we bought it with 49,000 and here's what the belt looks like. It may be original but we aren't positive either way.
I would replace it. There is a high probability that the belt is 13+ years old. Age counts as much as miles. As I recall, the general standard is replace at 7 or 8 yrs, and you are way past that.
When dealing with extremely low frequency maintenance items like timing belts, you need to think more about the whole lifecycle of your car ownership instead of eeking it out until it's due.
Are you going to do the timing belt once or twice?
Do you see yourself doing it eventually or are you going to sell or get rid of the car before needing to do it?
If you see yourself needing to do it, then you might as do it now for both piece of mind as well as getting use of timing belt2.
Think of it like a pit stop on a race in simple terms (no complex strategies). if the race is 100laps, and you need 1 pit stop. You don't use up the tires for 75laps then put on the 2nd set for only the last 25laps, you split it 50/50 even though tires#1 weren't used up.
If the first timing belt lasted 13 years, the timing belt buys you 13more years (assuming your same usage).
So, if you know for sure you need belt#2, you might as well get it in service sooner and put some use on belt#2.
As a side note:
If the timing belt#2 isn't going to last to the end, then you extend belt#1 a bit more so you can avoid belt#3. If you're getting rid of the car soon, you extend so you don't need belt #2.
All this depends on if it's convenient and if you can schedule other service at the same time to save time and money,
e.g. apply the same logic for the waterpump that's often included in timing belt jobs.
Even if it looks good, and by the book it says inspect water pump; perhaps it's super inexpensive to just have your mechanic change the water pump at the same time rather then inspect, put it all togehter, then have to take it all back apart to replace 1 year down the road.
If you bought the car with 49K, it's not much of a leap to consider it original.
One minor concern:
Is this an interference engine?
If not, I'd be a little comfortable dragging my feet.
If it is, then change it or have it changed ASAP.
The original belt might well go another 20K or more.
It also might well not.
Interference or not, a new timing belt and associated parts will have your PT set for as long as it's likely to last.
Time to replace. You'll be kicking yourself in the butt if it breaks, wishing you did. You also probably don't want to be pulling the head, to replace the valves when it breaks.
Do an Internet search to get a feel for replacement interval, looks like ~100k miles. The belt does look a little funky and the mileage is getting there.
Timing belt, tensioner, water pump (driven by timing belt). It's pretty much standard procedure on Cruisers. It's a dual cam engine and the valves can crash into each other when the timing belt breaks. It's a bit of a job because the engine is a tight fit in the car.
In person it didn't look bad I mean it looks kinda old but you can still clearly read the marking and all. That being said I guess a gates brand belt would be ok?
Probably should have been replaced at the 10 year make to be safe. I'd probably go with an oem belt.
I did my 2005 neon timing belt at 150k and am pretty sure replaced the original. Old one "Felt good".
PT belts are probably a hassle. Save it for an ambitious Saturday.
Per talking with Trav, Gates belts are fine. But their tensioners are made in China so might want to get an oem tensioner if you replace it or if it's noisy.
Originally Posted By: Chris142
It has the pentastar On it.it's the original
I'd imagine if they replaced it with an oem one it would have that to though. She really took care of the car. Where I work we recommend timing belts on time and miles.
In person it really doesn't look bad but recommended age is 10yrs. The camera picks up dust and dirt and makes things awful.. I wish I knew if she did do it
