Should I bother with UOA or just change out?
VT
Have an '03 Accord V6. Currently running Amsoil 0w20 and a Wix filter. I have 6K miles and 8 months on the last change. My main commute is about 3-4 miles to work with the rare longer road trip. I was planningon running a used oil analysis at about 6 months but...well it's been a long winter. Thanks for the advise.
I would change it now - because eight months from now will be the end of November - just enough time before the lousy parts of next winter settle-in once again.
I wouldn't do change it or run a used oil analysis. I'd run it till you had full year or 10,000 miles. Then get a used oil analysis done to make sure it did ok. If at that point everything looks good. Then continue to do annual oci.
Would you like my filter as well?
nah just the oil, I will run it another 5K at least
Do you plan on running it alot longer? What oil change intervals are you shooting for?
I would say 10,000 mile changes with Synthetic are safe.
That's cool with me. I'm in no rush to change if I don't need to. I was mostly worried about my use being especially harsh given the short trips in cold weather. I did this specifically so I could go long OCI but some recent reading I've done here got me worried. I heard several recommendations that if you drive like I do, with lots of short trips, that you may be better with dino SM and 3mo/5K changes. But, if I'm gonna leave it in I will go get a used oil analysis just to be safe. If it looks OK then I'll do another at 1 year. Will I need to have a TBN in my used oil analysis? That was extra at Blackstone.
acohen100,
You'll definately want the TBN done-short trip driving usually means the oil does not heat sufficiently to evaporate out moisture which in turn leads to acid production and a depleted TBN. Under short trip conditions, TBN will likely be the limiting factor.
REDDOG
