Hi,
I recently tried an MoS2 oil additive in my manual gearbox. I used Liqui-Moly gearbox oil additive and mixed it with my current almost new 75W80 GL5 oil. I've renewed my clutch now and had to drain the gearbox oil (+additive) but I wanted to reuse it since it was only 1000km old. The gearoil is black due to the MoS2 additive. When I poured the mix back in I noticed that there was some foam building up in the funnel just by pouring some of the used oil in
I then tried with some fresh oil and there was no foam in the funnel!!!!
I wonder if this additive causes the gearoil to produce foam easily! This wouldn't be a good thing obviously. However I used only one tube of MoS2 (20g) in 3.4liter of oil and this is less than what is recommended (1 tube for 1-2 liter normally). This additive is well know in Germany and Liqui-Moly is known to be a "serious" brand... Liqui-Moly states that this additive can be used with any type (dino, semi or full synthetic) gearoils and it is designed for synchronized manual transmission.
Do you think I should immediately drain out this stuff or is it OK to leave it in? I can't say the additive improved anything but it didn't degrade the gearshift so I'd like to leave it in until the next oil change because the oil itself is pretty expensive. The problem is really not about effectivness of the additive but about its safety.
What would you recommend? Does foam produce in a funnel when pouring in mean that the gearoil + additive will produce lots of foam in the gearbox as well???
Thanks
Thanks
