Originally Posted by spasm3
I wonder if the slightly smaller gaps were easier on the coils.
For sure it is. A wider gap gives a smoother idle but puts more stress on the coil. When I was in school back in the points, condenser, rotor days they demonstrated the effects of plug gap, first a smaller gap then a wider gap to show the effects.
These were larger differences not just a couple of thou. the closer gap ran a little rougher and the wider much smoother but anymore it would misfire.
Modern coils produce much more energy than the old ones so wider gaps without misfire as the age are possible but it does stress the coils.
Ignition coils generally fail due to heat either generated internally from poor mechanical connection, shorts or loss of cooling oil in the case of old style coils or external due to their position on the engine, cracks or damage to the housing will also cause the coil to act up
There is no actual mechanical failure, static wire doesn't wear out but the insulation can be damaged by over stressing the coil causing internal temperature increase.
Some coil units like the 4 post coil packs, waste spark coils and some COP units fail early and regularly due to heat breaking the winding insulation down, if you have a car that is known for this its prudent to swap them out before they act up or fail. Others seemingly go on forever.
the best thing is to inspect them when doing a service, if it has cracked or burned boots in the case of COP coils there is a good chance it could fail sooner than later. Any coil with a crack or burn marks should be changed.
These will tell you almost everything you wanted to know about coils.
https://www.hella.com/techworld/uk/Technical/Car-electronics-and-electrics/Ignition-coil-2886/
https://www.autoserviceprofessional...ils-What-every-tech-needs-to-know?Page=1
