Short Spiral filter Tubes question.
manila philippines
Hi. I am newbie here.
I have sample OEM filter from friend, and when I open it there is Short Spiral metal filter inside membrane.
looks not normal to me, because I was open several oil filter and this is different from other.
I was think this is factory defect, if filter is wet with oil there are no inner support this area.
what might happen if i use this kind filter ?
and this is inside can, there are mark of paint spray.
when I was open other oil filter inside was clean and no paint mark.
is this ok for use ?
Hello, I wonder if it's a case of the stock used to make the center tube coming to its end. There was still enough material to stay in place while the filter was assembled.
Can the OP open another OE filter? Kira
