Shocks / Struts
I waited until 9 years/138K miles to replace all four struts on my Subaru and it was too long. One rear strut could not be pushed down beyond the half way mark. the other rear could be pushed beyond the half way mark but would not return beyond half way. The two fronts could be pushed down and would return but at about half the speed of the new ones. The ride is now much nicer and the excessive rear camber appears to be corrected (still haven’t gotten the alignment done quite yet).
Before I changed out my 29 year old shocks, i pushed down on each corner, it was some what easy to push down, the suspension rebound back without bounce. I swapped new shocks and it became much harder to push down on each corner. What a difference. The main reason i changed them is they were making a dragging noise everytime it rebounded from more than half stroke.
Just for reference, I changed struts and shocks on my 18 F150 at 40k miles because I didn't like the way it rode. Found out I had a bad shock in the rear. I replaced the OEM with different valved shocks/struts that are serviceable.
Reviving this old thread rather than starting a new.. My Acura TL has 107,000 miles on it. Trying to decide whether to get new struts or to wait. Car is slightly more floaty than it used to be, but definitely not handling dangerously. Does it make sense to wait until it is obvious that I need them, or just replace them now as long as I am bringing the car in for other servicing. (I don't have the time, energy or facilities to do the wrenching myself) so it will be a big investment--easily $1000 with the labor and parts.
Year?
Millions of miles travelled, some vehicles with 260k miles or more, not once have I ever replaced struts. Shocks that wore out, sure. Struts? For my driving, I consider them good for the life of the car, and they usually are. The roads are decent enough down here so maybe that makes a difference.
Around where I'm at I have 2 cars that they wore out by 160k (Corolla and Integra). I also have one stop and go local grocery car (Escort) worn out by 90k.
What if one has an air suspension? The air shocks hold air so IDK? It definitely feels floaty, but then again it is a Lincoln.
In an air suspension the air is just providing the spring. There still has to be some damping provided and 99.9% of the time that is by a gas charged hydraulic shock/strut.
I think the issue is that my car is the 6 MT model, they didn't sell many of them and they do have stiffer struts than the ones with autos.
Be prepared to replace to sway bar end links while your in there.
Just installed quick struts on our Chevy Traverse and the passenger side strut was leaking and toast. It took the sway bar end link with it. So I replaced both end links when doing the struts. Had to make a extra trip to the parts store during the job.
Update: My indy mech was able to source the struts. The Acura dealer where I bought the car told me they stopped manufacturing the rears, and they were out of stock with the fronts. What am I going to do 100,000 miles from now?
It took 9 years to go the first 107k; how long for the next 100k? While living in NY? I’m wondering if there is a good chance that the car will be gone by then.
That car should have good aftermarket support for a long time. id be almost certain kyb will have struts available for it, and they have a good performance feel without being harsh for vehicles like yours.
Monroe makes quick struts for the 2012 TL :)
If the TL uses the same struts as the Accord, then you have lots of aftermarket support :sneaky:
Thanks but Monroes are just not going to be in the same league with the factory strut cartridges. This is the TL 6MT--Acura's attempt to compete with the Germans. And I have had bad experience with KYBs. Would only consider factory or Konis.
