Shock torque spec 2003 Suburban
Florida
Does anyone know the torque spec for the upper nut and lower bolt for the front shocks on a 2003 Suburban 1500 LT 2WD?
3 Ratatats from my impact!
On my 2003 suburban 4wd there is no way to get a torque wrench on the top nut that i can see...maybe if you removed the inner fender.
I used a ratchet wrench on the top nut and got it as tight as i could...drove it and then checked again after it settled.
Bottom bolt..Tight as you an get it by hand is good enough.
Originally Posted by Imp4
You'll shear those upper nuts quite easily......
Maybe try this......
I'll be using my small impact.
