As some of you know, I have a 2001 Civic LX. It's time for all four corners to be replaced (111k).
I own the Helm factory repair manual and it looks really easy to get the whole assembly out, both front and rear. However, you then need to get the shock/strut out from all the mounting gear and the springs. Hence, a two part question:
1. How hard is it? Do I need a spring-compression tool?
2. Do I need to worry about all the seats and mounts and if so, where should I go to get them? Haven't found any online.
Thanks.
I got my seatbelt money back from Honda! $542.48 (Got seatbelt tensioner fixed, found out from BITOG member it's lifetime warranty, went to Honda, got reimbursed)
Thanks.
