Shell Helix HX8 Synthetic SN 0W-20
Doesn't ACEA A3/B3 & A3/B4 require min HTHS of 3.5?
What kind of trick do they pull to get a 20-weight up to 3.5 HTHS?
its definitely not correct.
If I had to guess, probably an incorrect spec copied from 5w30
Originally Posted By: timeau
Probably misprint. At least I see "API SN; ILSAC GF-5; ACEA A1/B1" on Shell UK
Thats not the same oil helix ultra is not HX8,
2 different oils.
if you go back a link to
http://www.shell.com/global/products-ser...-synthetic.html
you can pick all their "Full Synthetic oils"
