Originally Posted By: Pop_Rivit
Originally Posted By: ridgerunner
Mostly good advise here, except for the use of acid and salt. Backwash from a softner (mostly salt) will kill your bacteria in your system.
I suggest you look at a couple of studies done on that very issue. "A Quantitative Analysis of the Impact of Salt on the Microorganisms in an Aerobic Wastewater Treatment System” by S. Husain & C.D. Litchfield concluded the following.
Quote:
These concerns seem to be unwarranted. First, a typical residential sized water softener discharges between 40 and 70 gallons of water per regeneration. Through much of the regeneration process, fresh water is discharged, containing no salt at all, so the total concentration of salt is very dilute. However, during some stages of regeneration, the sodium concentration can reach as high a 5,000 to 10,000 ppm for brief periods of time.
To see if this level of sodium effected microorganisms typically found in anaerobic on-site septic systems, the study exposed these microbes to a worst case scenario of 10,000 ppm brine solution. The study concluded that “there were no statistically significant differences in the metabolic activity of the microbial community”, and that it was “unlikely that failures in domestic water treatment system are the result of exposure to the brine from home water softeners.”
Another recommended reading source is “Home Water Treatment System Discharges to On-Site Wastewater Systems” by J.F. Harrison and C.F Michaud. They found the following.
Quote:
The effect of putting softened water into septic system can actually be beneficial. There is a very low amount of sodium contained in softened water. For every grain of hardness removed, approximately 8 ppm (parts per million) of sodium is added. Although some naturally occurring water sources have very high sodium levels, softened water normally has a slightly elevated sodium level vs. untreated hard water. While this concentration is normally insignificant at typical hardness levels, these higher sodium levels are more in the optimal range for septic system bacterial growth, and can promote bacterial development
Don't believe me, dump salt on any living organism and see what happens...
Let me think. No, I don't believe you when it comes to septic systems. The idea of "dumping salt on a living organism" isn't a valid comparison to increasing the parts per million in a septic system. If your wildly exaggerated comparison was valid, the salt water oceans of the earth would be a vast dead zone of nothing but salty water.
Since we've had septic systems for nearly 4 decades, and a water softener for more than 2 decades, and never an issue with the septic system, I think I'll continue to believe the experts.
Sir, U are talking to an expert. Ocean organisms have evolved (have ways) to deal with salt in their environment. Go ahead put the backwash in the tank. Organisms in your septic tank will die off, tank solids will not settle out and will exit the tank (outlet filter or not), clogging up pipes and aggregate. I deal w/ septic systems on a daily basis. I design, permit, conduct soil testing, inspect, and repair old system every day. I've done this since 1994, I know my chit! I don't soley rely on and quote read materials, I live it, see it, and all to often, step in it. Sodium also destroys clay structure in soils to a point where it is no longer infiltrative, ie by by drainfield hello expensive replacement.
Also the first study U wanted me to look up states that this is for an "aerobic" wastewater treatment system. Sorry, a septic tank is very much an anaerobic environment.
