sealed beam upgrade recommendations
Canada
hi everybody! I have an 88 325is with the ellip headlights, but recently at the junkyard I picked up a set of sealed beams. I have the "smiley" cutout on my car headlights, but I'm thinking of the h4/h1 upgrade form sealed setup, as it's a bit different than what most run. My setup has corroded and broken adjusters so I want to go with something that's cheaper than fixing up my old lights...maybe something different? Anyone have a recommendation for the sealed beam upgrade? I'm looking for something with citilights in them thanks smile
PA
I'm an HID guy personally, But my XJ's (jeep cherokee's) that were sealed beam, I always replaced them with E-CODE housings that accept H4 bulbs along with a relay setup to achieve the suggested wattage. I think they were "autopal" brand from EBAY......
California
Another plus one for the Hella e-codes. I have a pair of the Hella Vision Plus headlamps on my '94 pickup and they're great. Also threw in a pair of Osam (not sylvan!!!) night breakers and the lights are x1000 times better than the stock units.
New England, USA
another + for the Hella true e-codes, not the Vision Plus which is or at least used to be a Hella light made to the US DoT standards. Cibie's are another alternative. I have both on similar vehicles (my LR's) and while I like the Cibie's low beam pattern a bit better than the Hella's, the difference is not worth the cost differential. Either is miles ahead of a sealed beam.
KY
I have Hella E-Codes and Night Breakers installed on my 1999 Wrangler- an excellent upgrade. I've installed Cibie or Hella E-Codes in every sealed beam equipped car I have owned since 1977.
