I've had a bottle of Seafoam sitting around for a while and wanted to try it on my Malibu to see if it will help with some oil consumption and rough idle. It's not a lot but it's almost a quart down after 5000 miles, but it has never used any oil before. I'm planning on changing my oil very soon as well, so I figured I might put some in the oil as well before changing it. I've used Seafoam a couple times in other other cars. It helped in one case but not the other so it's worth a shot.
Anyway, I was planning on using the brake booster line like is usually directed, but on my car it seems like the brake booster vacuum line goes directly into one of the intake runners which isn't very helpful. There is another line that goes from the valve cover directly to a part right before the throttle body. I was wondering if this will work well to suck the Seafoam in to the intake.
This particular line is part of a non serviceable PCV valve (built in to the valve cover) and recently I have noticed that there is oil seeping around the end of the hose so I know there is probably some build up of oil in the intake. I just want to make sure this will work okay for what I'm planning to do. Here are a couple photos showing what I am referring to: https://imgur.com/a/aq7hs
