The MS3's have a notoriously bad PCV system. I don't know about the regualar 3's. But if they are the same, this can work wonders. I'd also consider an Oil Catch Can with an extra PCV. Matt Diamond sells complete kits with everything you need plus a how to sheet for a very good price and it uses the best of the best parts for everything.
Originally Posted By: Ndx
I have Amsoil FOAM ... but I don't think that The FOAM is able to reach to Cylinders same as Sea Foam poured via Booster Line..
What About If I will use Amsoil Foam ( Intake ) and Sea Foam via booster Line ?
If you are worried about reaching the cylinders pull the plugs and spray directly into each one then cycle the engine to distribute the product. Install your plugs wait XX amount of time and restart engine and whoola each cylinder was treated. Change your oil afterward since you just loaded it with foam.
Originally Posted By: mechtech2
Why add Seafoam to your intake?
Better to use in in the gas tank, or preferably another modern amine type cleaner.
The mythical Sea Foam miracle propigated by the internet never seems to die.
Sea Foam really has NO business being used in the fuel system OR the intake plenium....
Better to get a modern application specific cleaner such as the 3M throttle body intake and plenium cleaner kit...for the fuel tank any cleaner with 30-50% PEA detergent is best and proven to clean carbon effectively without leaving its own residue behind.
