I had a couple vertical fender scratches and bird dropping damage (ran down the fender) repaired by a touch up specialist.
He filled the scratches (they were not through clear coat and could be felt with finger nail) with clear coat and sanded with 3,000 grit paper and polished it out. bird droppings were sanded and poished.
End result is quite good. Not perfect on the scratches as I can see slight ripples in certian light. I will use service again if needed. cheaper than repaint at $75.
