- Joined
- Jul 22, 2020
- Messages
- 405
Good afternoon,
The left fender and driver side door are duller than other body panels of car such as the left rear door. Here are some pics:
The paint polishing guy said that he would send car with fine grit sandpaper like 2000 and then use 3m perfect it rubbing compound 36060 with rotary buffing machine.
Thing is that I am afraid the cars clear coat is not that thick. As a matter of fact there is a spot of paint where the clear coat has already disappeared.
I am afraid that if the car gets sanded with 2000 grit sandpaper that the very small amount of microns of clearcoat on car left would get removed and then the base coat would not have any clear coat protection.
It was recommended to me to avoid removing the small amount of clear coat left if the car were to be polished to just use 3m perfect it polish 36060 with rotary polishing machine without the sand paper. Is this a good idea?
I dont want the left front door and left front fender to be dull but I dont want to remove the small amount of clearcoat left on the car.
Thanks
Thanks
