Anything wrong with using the above grease for the entire driveline on my 2006 Toyota Tacoma 4X4?I know that Toyota specs lithium based grease and both NLGI #1 and #2 lubes.What do you think?
Yes use this grease,the 274#2 will work fine ,your double carden joint specs #1,but this grease will do the job just fine,I had a Toyota and ran nothing but Mystik and the Schaeffers 274,till 242k, never replaced a greased part,the truck rusted apart in the frame,the 274 is a aluminum complex,and the Mystik was the JT-8 high temp,mostly the 274 was used.BL
