Sales Rep is correct. the application dictates the answer,,,,,,,, personally my truck has the 229 # 2 in front bearings and Mystik JT-8 semi in drive lines and steering knuckles....to make a point both are good choices ,though the 274#2 would be a wee bit better,if I would do it over in cold climant,by the way last brake job I took apart front,, looked and put back,, used same grease,still LOOKED same..no wear ,the 229 doing its job.BL
