Listed below are my last three analysis results from Dyson Analysis and Holt Cat labs.
2003 VW Golf TDI
Oil Schaeffer's #700 15w-45 blend
Miles on Engine 10246 /20305 / 30211
Miles on oil 4770 /10059 / 9906
Fuel soot zero /47 / 33
%Oxid 17% / 22% / 11%
%Nox 7.50% / 35% / 20.5%
TBN 6 / 9 / 9.5
FE ppm 18 / 21 / 20
FE /1k 3.8 / 2.1 / 2.0
Chromium 1 / 1 / 1
Lead 1 / 3 / 0
Copper 3 / 3 / 3
Tin 1 / 1 / 1
Aluminum 4 / 4 / 5
Silicon 4 / 3 / 4
Sodium 3 / 2 / 2
Potassium 0 / 2 / 0
Moly 83 / 99 / 112
Phosphorus 1132 / 1300 / 1425
Zinc 1286 / 1416 / 1635
Calcium 3272 / 3882 / 4047
Magnesium 15 / 18 / 12
water neg / neg / neg
fuel neg / neg / neg
Antifreeze neg / neg / neg
Starting Vis 14 to 16
Vis@100 13.8 / 15.0 / 14.9
makeup 0 / Oz / Oz
additives none -none - Lube control
fuel treat SoyShield -SoyShield - Soyshield & FP
Filters air/oil oem -oem - OEM
Note: All the make-up was Lube Control 5 oz initial application 2k into this run then one oz per thousand with two intervals missed, fuel additives were three Ozs soyshield per four gallons and One Oz FP per tank full. Two tanks were Power Service winterizer only due to expected cold weather.
Modifications: EGR adjustment and CCV oil separator added 8000 miles into the period.
Many said I was crazy to trust my new ride to a synthetic blend. Not too shabby for a $12.00 a gallon oil.
Comments or observations?
[ March 12, 2004, 11:42 PM: Message edited by: Neil Womack ]
2003 VW Golf TDI
TBN 6 / 9 / 9.5
FE ppm 18 / 21 / 20
Chromium 1 / 1 / 1
Lead 1 / 3 / 0
Copper 3 / 3 / 3
Tin 1 / 1 / 1
Aluminum 4 / 4 / 5
Silicon 4 / 3 / 4
Sodium 3 / 2 / 2
Potassium 0 / 2 / 0
Moly 83 / 99 / 112
makeup 0 / Oz / Oz
