Have been using the #258 right at one year on the undercooled '01 Cherokee. Saw slight temp drop, Ph was good until change (5-months). Have right at 7-months on current use of XEREX GL-5 & distilled water (mixed to provide -25F protection per factory guidelines; roughly 50/50)
(System was drained, one radiator fill at a time with distilled until ran clear; used PRESTONE "drive it around" citrate cleaner for several days; again, slow-*** drain and fill with distilled, ran as rinse -- per whatever the instructions -- and again, one rad fill at a time made up with above combo. System has had coolant changed annually [13k, 38k, etc, now at 77k], hoses at end of two years [38k and due again].)
Have been somewhat perfectionistic as this vehicle has a minimally-sized cooling system (13-quarts for 242 cid, ps, pdb, auto, a/c; weighs 3400# in general use) and other users report the cooling system as being marginal in re replacement of radiator/water pump etc at an earlier point than I am used to (33 year-old Chrysler 383 now on second one).
#258 seems to keep the Ph in bounds, even in this hard-run (but well-maintained) system. Have done some towing, and have a 1k trip scheduled at present for August, Dallas to Chicago in the usual 100F weather pulling a 4000# trailer, and vehicle to max.
Believe that #258 provides a bit of margin well worth its low cost. Was not ever really pleased with Water Wetter. Wish I could say something about RMI-25, be glad to learn more.
