Are any of these trailers used to haul a boat? If so these need Marine Grease.
If not, then Lucas Hub Oil should be ok and is not their EO stabilizer.
The viscosity of each is about 85 cSt and each contains AW additives, plus Schaeffers 132 has a few more AW additives. so the 132 may work as well.
I would try the 132 on one trailer and after a year of use, inspect the bearings and compare them to the ones that had the Lucas Hub Oil.
The
