saturn s series ac clutch
North Carolina
My sons 01 sc1 has a bad a/c clutch. It won't engage even with a can of r134 attached. With the ac switch on and the fan on full. i do measure 13 or so volts in the wire going to the clutch. The shops around me will only change the entire compressor to the tune of $800. No one nearby carries just the clutch. I can get a compressor from a u pull it yard for $50 bucks. I plan on removing the clutch from this compressor and installing it on the existing one. How hard and what tools do i need to remove and install the clutch?
Thanks
Sounds like your coil is bad. I can't remember ever changing one on a saturn but I assume you will need a ac clutch tool set. We don't normally mess with replacing clutches and coils. Often the cost of those parts (new) is more than a whole compressor with clutch.
Seems pretty hard to find proper tools but this may vary by model:
Saturn A/C compressor clutch
My 99 SL2 compressor bearing was noisy. I ended up having shop install a re-manufactured compressor which made A/C work better and took care of the noise.
Here is someone who was successful. Maybe laster years are easier?
Clutch removal
If you can turn the clutch by hand,power going to the plug,a can a freon attached and nothing ? ,,,, you have a obstruction in the system ,,condenser or evaporator
There is also a magnetic coil in the clutch that when energized engages the compressor.
Good luck finding a junkyard compressor that works. Those cars typically get 12-13 years out of the factory unit.
I am trying to remember if a Saturn S-Series AC compressor is hard to DIY. I haven't had to do this job in over 5 years.
Its only the coil i want to switch out from the junkyard unit to the existing compressor, that way i don't lose the r134 already in there.
Oh, okay...
That sounds like a great idea then. I hope you can find the right junkyard part, because typically clutch problems are not what kills the compressor. Instead, it leaks internally and doesn't build pressure.
Oh, okay...
The clutch won't engage i checked and there is voltage going to the coil, yet it just freewheels. I just need to get the proper tools to remove and reinstall the clutch/pulley to get to the coil underneath. I have located a car i can pull the compressor from ( $50) in a u-pull it lot. I plan to remove that coil from the junkyard compressor.
Sometimes it is something as simple as excess clutch gap. Turn your AC on, with clutch coil getting voltage. Use a screwdriver, or something that fits and hold it in front of the clutch plate. If you get a magnetic tug on it, but the compressor doesn't engage, pull off the clutch plate from the compressor input shaft and pull out a shim until the gap is reduced enough for a proper engage.
I am not sure of the exact clutch setup on your system, but all of the compressors I have dealt with had shims used to adjust clutch gap.
