Saturn owners … what’s your consumption?
LA
I am inspired to start this thread because many of us driving saturns have to deal with a common problem of consumption. I’d like to see what your average consumption numbers are to establish a base and have any of you fought consumption with either changing oil brands or viscosity. Rather than saying that brand oil X is better than oil brand Y, I’d rather get your take on what has worked best for you.
So let me start, I have a 2001 SC2 1.9 DOHC with 50K on the odometer. Consumption has been the same from day one, at 36K when I bought the car. I have gone through the auto-rx treatment, after which I have changed to synthetics. Whether using conventional or synthetic consumption numbers have been the same, using the same grade 5W30. I was thinking of using 10W30 however I do see that some of the 10w30 oils are actually thinner than the 5w30. I was thinking either trying a HDEO or bumping my oils up a grade to a 10W-40. Notice I have not mentioned any brands as they have showed just about the same consumption numbers.
My other car a 2002 SL1 1.9 SOHC with 82K on the odometer, consumption numbers have been around 1qt per 5K miles, I have tried various 5W30 synthetic oils, they all have showed just about the same consumption numbers. I don’t remember what the auto-rx clean/rinse phase consumption numbers were because it has been a while since I have done so. Had the car since 42K miles and here I am too thinking of trying the 10W40 grade or the HDEO oils.
I do understand that with the 10w-40 grade MPG may take a slight hit, we all share the common oil ring problem where no matter what we do, those oil rings just do not seat properly and do let quite a bit of oil pat them. Both were cheap cars so I am treating this as a fun experiment rather than being annoyed that I have to add oil every once in a while.
My wife has a 2001 L300 she bought brand new. I'm the only one to ever change the oil on it. It has the Opel V6. Believe it or not, this thing uses NO oil. I run Quaker State 5-30. Car has 104,000 on it now.
It's only the 1.9s that had the oil burning problem. Of course, other engine designs aren't going to do the same thing.
I've owned 4 old Saturns:
91 base SL, 93-96-98 SL2's. Only the 93 had consumption problems.
The current one, 96 SL2, has 174K, doesn't burn a drop between changes unless the A/C is on (that's a symptom I've seen on all my Saturns) or Group III-based 20wt synths. No other oil consumes.
So did I get a "good" Saturn? No. It was built just like the rest of them (including the headliner canvas that flops in the wind! LOL. The reason: I used Auto-Rx and LC often. The other 3 Saturns only saw 3K OCI's as I owned them before I went with longer OCI's. Just today, I changed out the Pennzoil 5w20 conventional that had 7300 miles on the OCI (UOA to follow). Total consumption on this OCI with a 20wt oil: 2/3qt...the A/C was on more often during these hot summer months.
The ring problem is solved by getting & keeping the carbon out of the rings either by solid chemistry (Auto-RX a couple times then LC) or by manually changing the rings out of the engine. Option #1 is infinitely easier and the route that I took.
Our '96 SL1 has around 210k on the engine and is burning a quart every 5-600 miles. I've done two piston soaks (one with MMO and another with Berryman's) to no avail. And after popping the valve cover and seeing how much camshaft has been shaven off, I'll just top it off until it dies
