Originally Posted by SirTanon
If I'm not mistaken, the Mazda 6 i Touring has the same 2.5 liter i4 engine used by the Ford Fusion (the L5-VE). Assuming yours does, then the engine in your Mazda is the same as what's in my Fusion, and I've run 5w30 oil in my Fusion at least as much as, if not more than, I've used 5w-20 oil, and it's never been a problem. Considering you're in TX, I wouldn't think a 5w30 would be a problem in your 2.5 either.
Considering that the other two cars you're referring to also spec 5w30 oil, I would expect that you could simply utilize the Castrol 5w30 or Pennzoil 5w30 for all 3, and not give it any more thought.
Yes, it is the same engine as your Fusion. The 2010 Mazda 6 is kind of a Ford/Mazda mashup before that partnership ended. I view the Mazda as a Fusion with a Mazda body, interior, and suspension. I believe the 2 cars were actually built in the same factory in Flatrock, MI. The current model 6 is built in Hiroshima I believe.
Thanks for sharing. That's great that you have that many miles on your Fusion. Has a been a good car for you overall?
