RX330 ATF change plan with OE fluid
So we've got a 2004 lexus rx330 that is our daughters and has been pretty good. 145k miles. I replaced rear shocks/struts, changed rear diff/xfer fluid, and on 2nd change of Valvoline Restore and Protect 5w30. When we bought it I did t-belt etc. It's received a transmission drain with castrol transmissionmax import and new filter. (Unfortunately I didn't take notes and I don't remember if I drained it more than once so I don't even really know the mix %.). Originally my search was between the Castrol import and Valvoline MaxLife... in this transmissionmission the front diff shares fluid... So I started to think about the oem 3309/t-iv OEM.
Well the transmission still acts a bit silly sometimes. A lurch shift every now and again, and a slow shift 1-2 or 2-3.
Toyota just had their huge 25% off deal with free shipping and so I picked up a couple cases of t-iv for a song. I think the drain and fill should be somewhere around four quarts, so I think I will do two or maybe three if I can get away with it to get all fresh t-iv in it. If it's still acting up I probably will add a bit of lubegard red to help clean.
In a world of always newer and better, I thought maybe boring OEM would be best for the old girl.
Did the transmission act silly before the first ATF change? Had it ever been changed before the 145k point? :unsure:
Honestly, I'd just throw in the Lubegard and see if that works.
I did my own work on our Subarus, I did two drains a few hundred miles apart. That seemed to get rid of a good amount of old fluid. I don't remember the exact computed percentage, but there is a point of diminishing returns on the extra drains. No issue with adding lubegard on the last fill.
I *think* similar behavior, but I've got a pretty atrocious memory and it was 2 years ago. And before that I don't know. I would think yes, though, based on the other things that seems to have been kept up on it earlier in life. And I don't remember the fluid being just absolutely smoked when I drained it either which would have stood out to me.
The t-iv won't go bad, I could lubegard it now I suppose.
I make it a habit to drop the transmission oil at an annual service during an engine oil change. Once the system is clean you can stretch it out to every two / three years but at the start (new-to-me vehicle) I would drop the pan, clean & add magnets, and do at least three drain & fills.
Never add anything to your transmissionmission fluid unless it's called for (friction additive for LSD). Transmissions don't get dirty like engines & fuel injectors do. A quality transmissionmission fluid is extremely optimized as it is, right out of the bottle. Adding anything to a quality transmissionmission fluid is not going to improve anything, only make is worse in some way.
